Cloud solutions
Automate your infrastructure, propel your business
Choose from over 50 OVHcloud infrastructure services and managed platforms to modernise and deploy your cloud-native applications using your data and AI capabilities.
Embark on your Public Cloud journey
Your infrastructure managed by OVHcloud
Launch your project with computing resources, storage, databases, and a secure network in 1-AZ or 3-AZ regions. Get hourly, monthly, or long-term billing, and adapt your usage to suit your needs. Build the right IaaS for your projects!
Deploy applications at scale
Detach your applications from the underlying infrastructure with our managed Kubernetes cluster and container management solutions. Empower your IT teams to easily migrate, adapt, and scale your single and multi-cloud infrastructure.
Harness the power of data and AI
Make data collection easier by using our Data Platform (with over 60 connectors). Automate processing and leverage our AI models to enhance your applications, without infrastructure concerns. With Platform as a Service (PaaS), you can simply focus on your core business.
Discover Public Cloud products
Let us build your OVHcloud landing zone together
Define your target architecture with our OVHcloud business experts, consult the documentation and OpenTofu scripts on our GitHub, or contact us for support.
Benefits
Flexibility and scalability
Automate your infrastructure with our managed container and orchestration services. You can also add and delete resources directly via the OVHcloud Control Panel, or via API.
Predictable costs and transparent billing
Only pay for what you use. API calls and network traffic are included. If you’re opting for a long-term subscription, Saving Plans is a great way to save money!
Interoperability and standardisation
Feel free to mix and match various cloud technologies to suit your needs. Based on open-source standards such as OpenStack, Kubernetes or PostgreSQL, our cloud is interoperable and helps you avoid vendor-lock.
Resilience for your critical applications
We’re always working to provide you with cloud solutions (deployed in 1-AZ or 3-AZ regions) that meet the highest standards of availability and reliability, with the best price-performance ratio!
Data residency
Get your data as close to your users as possible by deploying in our Local Zones. We currently have 16 active Local Zones in various locations. Our goal is to provide 150 Local Zones to help bring you closer to your customers.
Sovereignty and security of your data
Regardless of where you choose to deploy it, your data stays your data. Most of our cloud services are already certified, while others are in the process of being certified ISO/IEC 27001, ISO/IEC 27017, ISO/IEC 27018, ISO/IEC 27701, SOC 2 Type II, CSA Type II and C5 Type II.
Explore the potential of the Public Cloud
Discover our comprehensive portfolio of Public Cloud solutions — Compute, Storage, Network, AI and much more — through an interactive and certification-focused learning experience.
Why choose Public Cloud instances?
Launch your project in no time
Public cloud instances (virtual servers) offer both flexibility and speed. In under a minute, you get CPU, RAM and storage, without over-allocating resources, as well as root access. The OVHcloud Public Cloud offers hourly billing, along with a number of features such as the ability to add resources without having to reinstall. With the OpenStack API, you can automate your infrastructure.
IaaS, PaaS, SaaS
There are different types of cloud models available, depending on your needs: Here, we find:
- Infrastructure as a Service (IaaS), which you can benefit from without needing hardware;
- Platform as a Service (PaaS), which lets you focus on installing and running your applications;
- Software as a Service (SaaS), which gives you software you can use without needing to manage it yourself.
OVHcloud is focused on providing IaaS and PaaS solutions.
High availability, simplicity, flexibility, and reversibility
Our Public Cloud is hosted in our datacentres, on servers assembled by our team. This empowers us to improve our performance and maintain control over our production chain, from manufacturing to launch. Public Cloud is easy to use, so feel free to manage it however you want. You can adapt it to your specific needs, thanks to its flexibility. What’s more, because we use standard APIs, your data is reversible. Lastly, our cloud is also interoperable.
How does Public Cloud work?
Public cloud is a model for deploying cloud computing services. Everything is shared—including resources, such as computing power or storage, as well as the physical infrastructure that supports them. Unlike the private cloud, where all physical resources are dedicated to each customer, they are shared between the provider’s users in the public cloud.
Who maintains the infrastructure?
Like other types of cloud solutions, OVHcloud maintains the physical servers and network, and manages the virtualisation layer. This means we can manage resource allocation, and ensure that our customers’ services are isolated. Automation is one of the cornerstones of Public Cloud. You can deploy instances (virtual machines) in a datacentre of your choice, via the OVHcloud Control Panel or API, with guaranteed resources in terms of storage capacity and computing power.
Where is OVHcloud Public Cloud deployed?
You can find all of OVHcloud’s infrastructure locations on our ‘Locations’ page
